Trunk Bike Rack Perfect Settings for 04 G35 Coupe with Spoiler
Old Mar 24, 2017 | 10:16 AM
bluemonkey136's Avatar
This is for the Thule 910XT trunk bike rack.
If anyone out there is having as much difficulty finding a bike rack for your 03-08 G coupe then I have an answer for you. I also have the stock spoiler as well with no issues. The manual will tell you to use setting 7 for the angle adjustment and that does not work at all unless you want a huge dent in your rear bumper and for your straps to come loose and loose your bike and rack. O_O
The fiberglass is too soft to tighten properly to as it gives way to weight and straps can constantly loosen. The best setting is 5 and to sit it on the lower region of your trunk where it is metal and try to keep the part your bike actually mounts to as level as possible.
Hope this helps someone.
