Random Leak. (Help Please)
Old Apr 23, 2017 | 08:59 PM
Batfinity's Avatar
I tried checking the Haynes Repair Manual to see if it can tell me whats actually leaking and well... the manual doesn't provide that information.
Im really hoping someone here can provide some information on my issue and help with some instructions but if not then i guess ill just have to take it a shop.
By the way... its not a result of rain or a car wash...
Thanks for taking a look at my thread.
If you're in the LA area and you help me out, It would be my pleasure to help you out with some bud or beer haha
Thanks again.
Attached Thumbnails Random Leak. (Help Please)-20170419_125135-1-.jpg   Random Leak. (Help Please)-20170419_125135.jpg
Old Apr 23, 2017 | 10:17 PM
gary c's Avatar
You need to tell us what's leaking, radiator fluid, oil or trans/clutch fluid? Radiator fluid, have a pressure test done, that will tell the mechanic where the leak is and what needs to be fixed! The rust kinda tells me it might be radiator fluid! I can recommend a good independent Nissan mechanic in the Valley who can solve your issues...CarZone (818) 373-1330 ask for Donald!
Gary
Old Apr 24, 2017 | 04:06 AM
partyman66's Avatar
That's not a leak. It's the drain tube from the A/C evaporator dumping out water. The drain tube is right over there where your picture is showing on the passengers side.
Old Apr 24, 2017 | 05:56 AM
Blue Dream's Avatar
I drove ttrank's car solo
partyman nailed it. It's perfectly normal so no worries OP.
