Only tail lights on? Is it possible?
May 24, 2017 | 12:06 AM
I would love to just have my tail lights running during the day. No side markers or city lights, just tail lights.
Aside from removing or disabling the sides and front city lights are there any other possibilities?
It would seem they all run on the same fuse so I don't think that is an option either.....
Reply 0
May 24, 2017 | 01:45 AM
Just leave on your parking lights, with a proper LED and clear corners I think they all look great together running as a DRL .
Reply 0
May 24, 2017 | 09:45 AM
I'm guessing if I am going to keep them on I would want a bright white on the side and possibly a hyper blue on the headlight. Any idea what size bulbs they are for each?
They almost look like the same bulb from what I can see without taking everything apart.
Reply 0
May 24, 2017 | 12:27 PM
Yeah, they are both t10 base 194 bulbs.
Would highly recommend soft white (5000k) on the front only, as blue on the car can get you pulled over by police for having lights that impersonate police.
Diode Dynamics sells some really nice bulbs that have great brightness even during the day and are pretty cheap. Otherwise superbrightleds.com
The side lights in the tail lights actually use a higher wattage incandescent bulb, if you would like to replace that, it is a T10 194 also. That one should be a red LED because of the law of filters.
Good luck.
Reply 0
May 24, 2017 | 01:17 PM
Red side markers? I would think police would pull me over for that before the blue inner.
BTW thanks for the info, your like the G35 grand wizard....Well one of them
Reply 0
May 24, 2017 | 04:43 PM
Spent a lot of time modifying this car and reading how to do it right I suppose.
Thanks.
Also have the FSM on my phone lol.
Reply 0
May 24, 2017 | 08:53 PM
man you need help.
Reply 1
May 25, 2017 | 01:18 AM
Quote: man you need help.
I had to replace a cam sensor on a date once. It comes in handy, okay!
Reply 1
May 25, 2017 | 09:39 AM
LMAO.
Ok fine one more question and I will take back the last comment.
Easiest access to headlight on an 07 C. Turn wheel and remove wheel liner and get it from the rear?
Reply 0
May 25, 2017 | 05:25 PM
Only if you're needing to replace a bulb. Easiest headlight access is to stand in front of a headlight and look down.
Reply 0
May 25, 2017 | 07:09 PM
Quote: Only if you're needing to replace a bulb. Easiest headlight access is to stand in front of a headlight and look down.
Awesome thanks. It was a pain going through the trunk
Reply 0
May 25, 2017 | 08:53 PM
I remove the wheels because my impact makes it take all of 15 seconds and I don't have to turn the car back on to spin the wheel back.
Reply 0
