Rear camber arm install question
Old Jun 7, 2017 | 11:39 PM
G35freaks's Avatar
I installed the front A arms today and am shooting for the rear camber arms tomorrow.
I can't find a good write up for just the camber arms. Anyone have a link?
I read something about dremeling the holes but I think it was for the toe bolts. I don't need to drill anything with just the camber arms right?
It looks pretty straight forward with the removal of the sway bar bracket.
Anything else I need to be worried about?
Old Jun 8, 2017 | 05:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
You should be golden, it's a simple process. The toe bolts are the ones you need to enlongate the holes they fit through but the arms are straight up bolt on.
Old Jun 8, 2017 | 09:28 AM
G35freaks's Avatar
what I figured and thanks for the info!
Old Jun 8, 2017 | 10:39 AM
LoSt180's Avatar
It's straight forward, my only addition tip would be to jack up the suspension before tightening down the bolts for the arms. This will help extend the life of bushings, and will align the adjustable bolts properly (unless you're using blockout plates).
