Lights draining my battery help
Old Aug 18, 2017 | 03:29 AM
Justin Vendiola's Avatar
So these lights won't shut off. Can't figure it out. Replaced the rubber grommet behind the pedal already also if anyone had this problem lmk can't drive it any where or my battery dies. When I press my brakes nothing happens as well
Old Aug 18, 2017 | 05:24 AM
$Carnage$'s Avatar
You have a bad electrical ground somewhere most likely.
Old Aug 18, 2017 | 05:17 PM
IMfam0us's Avatar
Did it just randomly start doing this? Pull the fuse for right now when you park it. That will save your battery. Agreed that it might be a wiring issue. Something is grounding out or wires may have been rubbing, have no coating now and touching
Old Aug 18, 2017 | 05:45 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Last person who had this issue it turned out to be a broken piece that holds the actual switch on the brake pedal stop, not the grommet that pushes the switch. Unplug the switch and ri g it out with a digital multimeter, should be closed (0 ohms, continuity) when the brake pedal is depressed. (Normally closed switch).
