City light flickering
Old Oct 3, 2017 | 04:07 AM
NyCrAzY's Avatar
Hey everybody,
My city light has been flickering on and off for the past month and it’s really annoying me. It’s an LED bulb that I installed last year. Because it keeps flickering on and off, is it most likely the bulb or a fuse/wiring type of issue? Thanks.
Heres a video of it:
P.S. I don’t know if it’s actually called the city light or daytime running headlights. So correct me if I was wrong.
Old Oct 3, 2017 | 07:54 AM
telcoman's Avatar
Veteran: Army
Originally Posted by NyCrAzY
Hey everybody,
Heres a video of it: https://youtu.be/ICTidmbrZqM
Why haven't you tried replacing the bulb?
Telcoman
Old Oct 3, 2017 | 08:15 AM
gary c's Avatar
Check the wiring, then the connector if everything is clean and tight replace the bulb! If it works...taaadaa!
Gary
Old Oct 9, 2017 | 05:29 PM
Urbanengineer's Avatar
If it’s not a high quality bulb (read it was less than $6 a bulb on eBay) it probably is your problem.
Also a small chance in hell that it just has LED Flutter and you need to install a resistor.
