Tiptronic Seems to be downshifting on its own.
Old Oct 31, 2017 | 11:32 AM
07G35Guy's Avatar
Whenever im crusing along in tiptronic mode ill be in 2, 3, 4 or 5 and it will automatically start downshifting as far as it can, even when im accelerating. Sometimes it will not let me upshift either, i was wondering if you guys have every come across this problem? any suggestions?
Old Oct 31, 2017 | 11:39 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start by cleaning up the transmission ground, it's located at the front of the engine on the very top, there are two 10mm bolts with a wire lug landed to the front of the timing chain cover, one is the transmission. Remove them, use a wire brush to clean up the bolt, lug, and the fece of the timing cover. Apply a little bit of electrical oxidation inhibitor grease (available at any parts house in a tiny packet) to everything and bolt it back up. Many time poor shift characteristics or transmission problems can be as simple as a bad electrical connection and the G is NOTORIOUS for this.
Also check your AT fluid level, fluid change interval is 30k so if you're past that interval mark then you're due...
Old Oct 31, 2017 | 11:44 AM
07G35Guy's Avatar
I will try this when i get home tonight and give you an update. Also the car has about 133k miles on it ive only had it for the last 15k, I'm not sure if the car has had any ATF changes ever. Is there anyway to tell how long its been since the last change? Thanks
Old Oct 31, 2017 | 11:46 AM
cleric670's Avatar
BANNED!!!
Err on the side of caution, American's are notorious for never changing their AT fluid for some reason, it might have the full 133k on the stock fluid...
Old Oct 31, 2017 | 11:49 AM
07G35Guy's Avatar
ouch, 10-4, ill check what the fluid looks like, I hope that's not the case.
Old Nov 6, 2019 | 06:20 AM
Dio23's Avatar
2005 Infiniti G35 Fully loaded Stock mods
I have the same problem.
Hey I am bringing this thread back up because I have the same problem and was curious to know if you were able to fix this?
ntxhw lor
May 5, 2016 08:30 PM
