Passenger headlight
Old Nov 10, 2017 | 10:24 PM
Dwight Cobb's Avatar
Passenger headlight
Advice on passenger side headlight have replaced light checked fuses and balliser still nothing any advice
Old Nov 10, 2017 | 11:48 PM
IvoryPearl07G's Avatar
Check the connectors for any bent or damaged terminals. Check that you are getting power to the connector. Check continuity.
Take the bulb and try it on the driver side. If it works, that is eliminated. Do the same for the ballast. If that works, that is eliminated.
Report back here with your findings and we can go from there...
Old Nov 11, 2017 | 12:05 AM
Urbanengineer's Avatar
I’ll be doing this soon. My drivers just went out... new bulb as of a few weeks ago!
Old Nov 11, 2017 | 03:11 PM
jgonz951's Avatar
Please keep in mind G35s are equipped with HID's from factory. So it may be a bulb or ballast problem.
