Tbs actual difference
Old Feb 14, 2018 | 10:12 PM
2k5g35coupe's Avatar
Ok so i know alot of people on this forums are going to disagree with me heavily.. after reading all the other posts on tbs i know it's not going to give me any gains what so ever. But anyways i decided to install one after my 5/16 md plenum spacer because even tho i felt gains, i still felt laggy when i got on it since im at auto. But after i installed a tbs i got way better throttle response at the beginning. So it does work on acceleration. Does anyone have this?. And i know it's not placebo effect.
Old Feb 14, 2018 | 10:17 PM
herrschaft's Avatar
Did you perform any relearn procedures after installing it?
Old Feb 14, 2018 | 11:14 PM
I just slapped it on and tried it out. I was thinking of resetting the throttle body but it feels like it made the md 5/16 spacer come to life.
Old Feb 15, 2018 | 11:00 AM
SoCal04G35's Avatar
i always reset my ecu after major upgrades, and yes i noticed throttle response increase with my spacer. get a grounding kit (make sure it has AT grounds) to help with lag, or if youre rich get the transgo valve body upgrade
Old Feb 15, 2018 | 11:10 AM
LexD's Avatar
Originally Posted by OCG35
it was determined even though there was an initial 10 HP gain in the first 5-6 pulls of each set, the G went back to base line numbers after that. Therefore, the increase really wasn’t the TB spacer but the ECU playing tricks.
That tricky ECU
Old Feb 15, 2018 | 11:15 AM
I will do that today.. do i reset my ecu by disconnecting the ground on the battery?
Old Feb 15, 2018 | 11:17 AM
LexD's Avatar
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. Done!
https://g35driver.com/forums/engine-...-easy-way.html
Old Feb 15, 2018 | 02:18 PM
SoCal04G35's Avatar
im lazy and just do the remove negative battery cable, then hold the brakes for a few secs. seems easier than the pedal dance
Old Feb 15, 2018 | 02:30 PM
Yeah thats what i did with the md spacer.
Jon81035
V36 Engine, Exhaust, Drivetrain & FI
Jul 6, 2009 03:40 PM
AzekOne
Intake & Exhaust
May 14, 2007 09:42 PM
Jkim79
Oct 30, 2004 03:33 AM
