Cooling fans only work on high, not on low
Old Mar 22, 2018 | 09:39 PM
Agustin98's Avatar
So I have a problem with the cooling fans. There so loud I could even hear it turn on every 45 seconds. I know the low fans are suppose to turn on at 207 and the high fans at 212. But only high fans turn on at 207. When ac is on the low fans do come on , any suggestions ? I Campared my car with other g’s out there and their fans seems to be working on low Except miner
Old Mar 23, 2018 | 12:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There are 3 cooling fan relays in the IPDM and it sounds like one of them isn't working. You know it's not the fan assembly itself since it does operate at low speed with the AC running and it does operate at high speed once it crosses the 212F threshold.
Old Mar 23, 2018 | 01:19 PM
Agustin98's Avatar
Thanks ! Will be checking
It out, Which relay is it ? I know there’s 3 in the ipdm ; cooling fan relay #1 is in the middle cooling fan #2 is the last one and cooling fan relay #3 in the first one on the ipdm overall what relay control low and high speed ?
Old Mar 23, 2018 | 01:52 PM
cleric670's Avatar
BANNED!!!
I can't remember which relay controls what. Personally I would just test them, 12v across pins 1 and 2 will close the two different switches which are pins 3, 5 and 6, 7.
Pretty sure those are the relays for it but I didn't doublecheck my car.
Apply the 12v voltage then use a digital multimeter to read continuity (ohms) across the two switches. It's best if you make little test leads and crimp some sta-kon connectors so you have a bunch of wires coming off the relay instead of trying to carefully probe the actual terminals then you can just wire nut your 12v leads on (fuse protect just in case).
Old Mar 23, 2018 | 05:55 PM
Agustin98's Avatar
Is it cooling relay #1 that operates low speed ?
[img]webkit-fake-url://5dc20cac-8e60-4538-bf1c-d8a106875093/imagejpeg[/img]
incautious
Jul 27, 2016 07:32 AM
user 82020
Engine-Vendor
Apr 5, 2015 04:19 PM
superman22x
Aug 19, 2012 08:33 PM
redlude97
Jun 28, 2006 11:36 PM
