Coul over question
Old May 30, 2018 | 11:35 AM
Rmeekg35's Avatar
Coil over question
When I purchased my g35 the guy gave me new coil overs to go with it. Had an issue, front went perfect, rear lowered car to much and wheels were jammed into wheel wells, yes hey were maxed to the top after install, any suggestions or should I purchase a different set so I know what I’m getting? Front sits exactly how I want it, rear needs to go down an inch or 2 from where it sits now.
Old May 30, 2018 | 12:35 PM
eazdaskeez's Avatar
What kind of coils are they?
Old May 30, 2018 | 12:42 PM
Rmeekg35's Avatar
There was no name any where on them, they are like green in color, saw similar sets on eBay pretty cheap.
Old May 30, 2018 | 03:08 PM
Conissah's Avatar
Cheap and green, they're probably RaceLand, or worse. I'm confused by your wording. Are the coils on the car now and you're not happy with how the rear sits, or were they on the car and it was too low so you removed them...? Are they true coils in the rear or still a separate spring and shock?
Old May 30, 2018 | 03:19 PM
Rmeekg35's Avatar
They were not on the car, they were in the trunk still wrapped in plastic. When I put the rear on it dropped it so much I couldn’t lower the jack the entire way, so I put the original back on the rear. From where it sits now on rear it was about 3.5 to 4 inches lower with the coil overs installed. They are installed on the front. I may just order a new set that I know is of good quality, plus I will know what’s on the car if I do it that way.
Discount Tire Direct
Wheels & Tires-Vendor
May 30, 2018 11:33 AM
