Help please vacuum leak problem?
Old Jun 24, 2018 | 11:47 PM
Rav5master's Avatar
Hello G drivers! I did a vacuum smoke test and found bad gasket below intake. Please look at pictures i have no idea what this is?
Attached Thumbnails Help please vacuum leak problem?-20180624_224015.jpg   Help please vacuum leak problem?-20180624_222447.jpg
Old Jun 25, 2018 | 12:15 AM
coffeysm's Avatar
Lower intake manifold?
Old Jun 25, 2018 | 12:20 AM
Rav5master's Avatar
This thing has an insane intake manifold makes sense... Thank you for replying. I will keep update on findings. If you know torque specs on intake bolts?
Old Jun 25, 2018 | 12:36 AM
coffeysm's Avatar
Not of the top of my head, but I remember the top ones are like 100-INCH pounds. That is like just slightly above tight by hand I think. I imagine the lower ones are probably around the same and you're probably leaking from that gasket.
Old Dec 19, 2020 | 07:36 AM
Bongizzle's Avatar
G35 sedan
Its a long shot but where did you hook up the smoke test to? I'm trying to do mines cause my idle is insanely bad like rpms go up and down and acceleration is fine then when I come to a stop it dips real low then dies and I have to restart it.
ACE420
Intake & Exhaust
Aug 15, 2014 08:30 PM
Andrei
Dec 18, 2010 12:49 AM
Klubbheads
Intake & Exhaust
Mar 17, 2008 05:47 PM
chester
Not G35 Related
Jan 9, 2008 08:16 PM
