Heat seat button fell through
Old Aug 18, 2018 | 10:22 AM
thatguysky's Avatar
hey guys. In need of some help. As the title suggests my heat seater button fell through the hole. What’s an easy way to get under the panel and retrieve it. Where are the points that I should lift up on the panel?
Old Aug 18, 2018 | 04:40 PM
Scorpi0's Avatar
Remove the center console. U can have it off in 5 minutes.
Old Aug 19, 2018 | 01:33 AM
Magneu's Avatar
5 Year Member
G35C 5AT
Remove shift **** (lower silver trim below ****, remove gold clip), use a trim remover to raise shift panel, done. This assumes you have a 5AT; I imagine 6MT is even easier.
Old Aug 19, 2018 | 04:13 PM
WallyLO's Avatar
If you have a 5AT, take the advice above, but be very careful removing that gold clip from the shifter. That thing will go flying. And if it does, good luck finding it.
also, when I've removed the center console in mine, I turn the key to acc and put the shifter in the drive position so that the center console can pull right out.
SCOTT88
Jul 20, 2008 05:59 PM
edindaclub
Interior
Oct 25, 2007 02:03 AM
WILD121
Florida G Club
Oct 6, 2006 09:47 AM
Evangelo2
Dec 6, 2005 03:56 PM
