Dealership quoted me $4000.. any help??
Old Oct 2, 2018 | 01:44 PM
yunglawwd's Avatar
Hey there guys so my whole lh curtain airbag system is down bought it like that from previous owner stealership is quoting me a ridiculous 4000 for the parts and labor(btw that’s almost the amount I paid for the car)
wondering if all coupe years curtain airbags are interchangeable regardless of years bc I saw some cheap used one on eBay. Also needs a sensor and module.
Old Oct 2, 2018 | 03:03 PM
Edgarc6789's Avatar
I'll say it does fit all coupes but double check I'm 99.9% it will 03-07
just disconnect the battery before doing it
and the airbag module has to be replaced or reseted (cheaper been reset but idk if theres anything bad by doing that I've done it )
You dont need a new belt ?
Old Oct 2, 2018 | 03:07 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah I think all SRS airbags equipment is interchangeable as long as it's from the same chassis (coupe/sedan). Fortunately the system is a standalone setup, if your diagnostic control module (brain box in the console) has been in an accident it must be replaced but there is no dealership programming, just install all the parts with the battery disconnected and once it's 100% hook the battery up and turn the key to ON, it does a self-check every time you turn the car on.
Diagnostic control module, driver airbag, seatbelt switches, seat airbags, etc can be from either chassis. It's possible the side curtains are as well but I've never compared them.
Old Oct 2, 2018 | 03:14 PM
cleric670's Avatar
BANNED!!!
If the seatbelt auto retractor pin has been popped you need new seatbelts. You can Google how to put the SRS system in diagnostic mode then it will flash a Morse code on the dash and tell you what systems are inoperable.
G35_sylvi
Nov 9, 2007 12:36 PM
JoeP
Jun 30, 2005 03:39 PM
BobbyG123
Jun 1, 2005 10:15 PM
Corgidog
Jan 18, 2005 07:46 PM
Triji
Intake & Exhaust
Dec 1, 2003 10:21 PM
