Help With feed line
Old Mar 20, 2020 | 04:54 PM
S1lv3rg35's Avatar
Stock for now
Help With feed line
Hey guys I recently bought an 03 g35 coupe and had some issues with it. One of the issues I’m was when I check out the fuel pump that sits under the seat it was leaking out of the fuel feed line where it goes from steel to nylon and was wondering if there was any way to fix this your help is gladly appreciated
Old Mar 20, 2020 | 10:39 PM
chasracer's Avatar
From your information, I would suggest that the nylon clip that holds the line in place is toast. You can get new clips at most auto parts stores and the ones that are usually marked as fitting Chrysler products are the correct ones.
Old Mar 21, 2020 | 01:44 AM
S1lv3rg35's Avatar
Stock for now
Thanks for the reply. I changed that part as well but saw that it was leaking from the part where that nylon connects to the steel line
Austino
Nov 14, 2017 09:16 AM
KeepinItG35
Nov 17, 2013 08:45 AM
88G35
May 20, 2007 01:27 AM
