Engine Bay to Fuse Box Wiring Harness
Greetings, 2004 G35 2-DOORS AUTOMATIC VIN: JNKCV54E74M808909
I'm looking for this:
1) Engine bay to fuse box IPDM wiring harness: 24012-AM862
I need the whole BLACK wiring in this image and the IPDM/FUSE BOX.
https://www.infinitipartsdeal.com/pa.../wiring,,24012
Your best bet is definitely going to be finding one locally in a pick-n-pull wrecking yard.
If you have a harness but it's damaged then you should just repair it. You can depin harnesses one at a time and replace bad wires, time consuming but definitely works.
If you don't have a harness to work with or the IPDM connector is melted that's obviously not going to work though.
EDIT: If the connector is melted then just salvage one off any G35, depin it, put it on your vehicle.
DOUBLEEDIT: Worst case scenario you buy ANY front chassis harness and repin it to match the wiring configuration in the FSM. Shouldn't be too many changes between the 2004-2005 and the 2006-2007. You might need to salvage a couple 2004-2005 harness pieces off of any G35 of those years.
trexm3
May 22, 2020 08:28 AM
