Power steering pump bushing
Old Sep 10, 2021 | 08:11 PM
koko's Avatar
G35 MT
I cannot get the bronze bushing out to fit the new power steering pump in, Any ideas?
Old Sep 10, 2021 | 08:31 PM
Mr.GEE's Avatar
20 Year Member
Use a socket just smaller than the bushing OD and a deep socket with the inside larger than the bushing OD. Place the small socket on one side of the bushing and the deep socket on the other side with the large inside toward the bushing. Run a long bolt through the entire assembly and keep tightening the bolt until the small socket pushes the bushing all the way into the deep socket. To install the new bushing just run a bolt through the bushing and bushing hole and tighten it until the bushing is fully seated in the bore.
Old Sep 11, 2021 | 11:00 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably be cheaper to get a piece of allthread instead of a bolt. Bolts are expensive and allthread is cheap. Don't know why since allthread requires more metal but it's almost always the case when comparing it's price against long bolts.
Old Sep 11, 2021 | 01:22 PM
koko's Avatar
G35 MT
I tried that and it didn’t work, didn’t even budge, is a saw next?
Old Sep 11, 2021 | 02:00 PM
cleric670's Avatar
BANNED!!!
I guess the bigger question is why do you need to remove that bushing? The new pump should bolt directly in place of the old one.
Old Sep 11, 2021 | 02:01 PM
koko's Avatar
G35 MT
it doesn’t fit with the bushing there
Old Sep 11, 2021 | 03:45 PM
cleric670's Avatar
BANNED!!!
Are you sure you got the correct pump? Place it side-by-side with the original one and if it's not EXACTLY the same then they probably sold you the wrong pump.
ProjectG35x
Sep 25, 2019 08:17 PM
Hunt4m3x
DFW G35 Owners Club
Jan 31, 2010 01:01 PM
wiluspyder
Archived Sales
Dec 2, 2009 12:11 PM
3Point5Sedan
Dec 30, 2007 01:29 PM
