any benefit to upgrading rear mid links / spring arms?
Jun 2, 2022 | 10:10 PM
https://www.z1motorsports.com/suspen...m-p-13406.html
i ordered the s-tune suspension and the stock spring arms look trashed. besides looking better, any reason to upgrade this part? anything to gain?
Reply 0
Jun 3, 2022 | 11:42 AM
Nothing to gain except more height adjustability on normal springs.
Reply 0
Jun 3, 2022 | 11:56 AM
Quote: Nothing to gain except more height adjustability on normal springs.
toe adjustment too, correct?
Reply 0
Jun 4, 2022 | 10:38 AM
Well there's already toe adjustment at that eccentric bolt, but if you needed more adjustment than what a SPL bolt gives then you typically aren't running a lower spring bucket anyways, you would usually be running true coilovers at that point.
Seems REALLY expensive considering what you're getting.
I used to have S-tune springs on the factory buckets and didn't have any issues just running the Z1 camber kit.
Reply 2
Jun 4, 2022 | 01:08 PM
Quote: Well there's already toe adjustment at that eccentric bolt, but if you needed more adjustment than what a SPL bolt gives then you typically aren't running a lower spring bucket anyways, you would usually be running true coilovers at that point.
thank you sir
Reply 0
Jun 5, 2022 | 10:40 AM
Should mention I also have the SPL toe bolts that give the extra +/- 1 degree of adjustment. I think I had to run... -1.5 degrees camber on the rear to get toe in spec.
I don't have any of those old alignment reports unfortunately.
Reply 0
