2003 G35 TT mod help
Old Oct 26, 2022 | 09:25 PM
Drublaze420's Avatar
Infinit g35
Hello, new to the group. I picked up a twin turbo g35, 2003. I am looking to mod it out to pick up roughly low 500s high 400s. It is fairly stock for the most part as far as the block. What should I start with, internals, FBO, etc? What it has done so far is.. -
Greddy Twin Turbo Kit on 6.5 PSI
HKS SQV4 blow off valve
Berk test pipes with 370z y-pipe
Z1 clutch and midweight flywheel
Turbo XS tuned with Utec for 91 octane
RC 440cc injectors
Walboro 355 fuel pump
Mishimoto radiator
Z1 silicone hose kit
Z1 motor,trans, and differential polyurethane mounts
any tips is helpful, TIA. (:
Old Oct 27, 2022 | 03:39 AM
Scorpi0's Avatar
From what Ive read, the connecting rods will only hold up to about 450hp. Some people have pushed it slightly more, and some people have pushed it slightly less before they failed.
Wouldnt you already be pushing about that much hp with your current setup though?
Old Oct 27, 2022 | 08:59 AM
Infinit g35
No. I just got the car. The guy had it set up like this. He said it’s at about 335HP. He said I can make more boost but what Im asking is what mods i need to do to make more boost as far as internals, FBO, etc. I’m aware I can turn the boost up and run my **** into the ground, but I care about my car and Im looking to build it not just turn boost up till it gives out lol.
Old Oct 27, 2022 | 09:36 AM
Infinit g35
Do you think an engine rebuild kit is the way to go with FBO to increase boost safely for making power?
Old Oct 27, 2022 | 09:30 PM
Urbanengineer's Avatar
Yes lol, rods and pistons minimum. Low comp pistons are best for your turbo setup. Call Z1 and give them your ideal whp range and they’ll build you a cart.
Old Oct 28, 2022 | 01:26 AM
Infinit g35
I was gonna wing it with this kit -
Z1 VQ35DE Basic Engine Rebuild Kit Level 3 from Z1 and FBO from there.
SlideFox
Forced Induction
178
Jun 20, 2016 10:27 PM
Black Guy
Engine-Vendor
27
Mar 7, 2009 03:41 PM
SSREngineering
Forced Induction
Jan 6, 2004 07:08 PM
