Ecu Questions
Old Oct 5, 2023 | 02:04 PM
TurboCarlos's Avatar
RevUp DE Coupe with Upper/Lower mani. (5/16 spacer), 75mm TB, intake, Admin tune, and coils.
Ecu Questions
Hi, I’ve been having the problem of blowing the ECM Fuse (fuse #77 15A).
The car has been in the shop for over a week and they’re having a tough time finding the issue.
Im tuned right now, if I need a new ECU will the tune go away? How can I transfer the tune to the new ECU?
Old Oct 6, 2023 | 11:53 AM
seymore4's Avatar
m56
If you replace the ECU you will lose the license and tune. Basically have to start over. But, that's actually a good thing since you were originally tuned by admin...
I can help you out, shoot me a PM
Old Oct 7, 2023 | 04:32 AM
MA77's Avatar
G35 6sd
Ignition coils?
something like this before here
Old Oct 12, 2023 | 02:25 AM
RhodaReilly's Avatar
mustang 1965
Any update?
Old Oct 13, 2023 | 10:18 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Start by unplugging all your ignition coils, exhaust cam magnet retarder if you have the rev-up, intake cam actuators, EVAP solenoid, cam sensors, crank sensor, and MAF.
That's everything getting power from the ECM relay which is powered by fuse 77.
See if it will hold, start plugging things back in one at a time until the fuse blows.
If it won't hold even with everything unplugged then you have a wiring harness issue.
mann1961
Mar 16, 2015 10:16 PM
.:Gthirty5:.
Sep 30, 2009 06:04 PM
jasonsfa98
Sep 22, 2005 08:58 AM
