Engine Not starting occasionally
Old Sep 7, 2024 | 06:54 PM
ILuvMyG35's Avatar
Hi guys I am back! It's been 20 years since I first bought my G35 Coupe new from the dealership. I still love my car just like my screen name says. Just that recently it doesn't start occasionally.
It's a Coupe 5AT. It only has around 50k mile on it. I kept many years in my garage. Only drove a few months here and there.
​​​​​​I have done all the oil changes. Did a coolant flush, ATF flush, replaced the thermostat. Battery replaced twice. I see cracks at the belts but will replace it soon.
So my problem is there one time it doesn't start on the first crank. But okay on the second attempt.
Another time I cranked it for 5 seconds and didn't start, I turn it off and started on the 2nd attempt.
Then there's a time I tried to start the car and the whole car black out as if the battery was dead. So I turn it off,prayed for a few second and tried again and it started. I first thought it might be battery related but I check the battery is full when I tried to charge it.
What do you guys think? Starter problem or spark plugs?
Thanks 🙏🏻
ILuvMyG35
Old Sep 20, 2024 | 07:12 PM
shurur's Avatar
2003 G35 Coupe
Could be a crank sensor that is failing intermittently.
my audi did this for years before showing a solid fault.
I am not sure about the g35.
Old Sep 21, 2024 | 09:27 AM
Mr.GEE's Avatar
20 Year Member
It could need a throttle body cleaning.
Sean Hopkins
Oct 8, 2018 07:28 PM
mpspeer
Mar 15, 2016 12:43 PM
cizzla7049
Oct 1, 2014 08:40 PM
Dean G
Aug 3, 2011 04:02 AM
Jubie210
Team 210 VQ'Z
Apr 22, 2009 11:34 PM
