2007 G35 Coupe 6MT / NEED HELP / NO CRANK!
Old Oct 16, 2024 | 04:55 PM
meskincfo's Avatar
5 Year Member
Cedan & options to come
I removed and recovered my dash over the weekend on my 2007 G35 coupe. I just finished all the assembly and now my car won't start. Everything powers up as normal, but no crank at all. Before the process of removing my dash, I did disconnect the negative terminal of my battery. Also, I did remove and unplug my instrument cluster, so not sure if that had anything to do with it not starting. I also did an ECU relearn but still no crank. I have re-traced all of my steps and still no crank. Would like anyone's feedback and help with this.
Thank you
Old Oct 18, 2024 | 06:59 PM
Mr.GEE's Avatar
20 Year Member
Check the switch near the top of the clutch pedal bar. You may have knocked it out of adjustment.
Old Oct 19, 2024 | 10:18 AM
meskincfo's Avatar
5 Year Member
That's what it was. The plastic clutch stopper broke off. Thank you!!
jsmall
May 9, 2024 11:56 AM
connie jo
Nov 13, 2022 04:13 PM
baumrr
Aug 6, 2022 07:13 AM
Jaay210
May 16, 2020 04:20 PM
triplebless
Interior
Apr 21, 2019 09:49 PM
