Whats the difference betwwen Slotted and Cross Driller Rotors?
Old Apr 10, 2005 | 05:31 PM
Potty_Pants's Avatar
Eagle1... you know your sht
very good answer to his question !
ppp
Old Apr 10, 2005 | 07:54 PM
GonSpeed's Avatar
What about rotors that are both cross drilled and slotted?
Old Apr 10, 2005 | 11:53 PM
Derek173's Avatar
Originally Posted by gangstadirty5
From the Mercedes-Benz new SLK brochure:
"At first glance, those little holes may not seem like much. But in a high-performance braking situation where rotors can get red-hot and brake fluid can boil, the ability to dissipate heat and vapors is vital. Rather than simply drilling holes in the discs- a method that can cause 'stress risers' that weaken the metal- the perforations in the SLK front brakes are cast in place to help maintain maximum strength."
I stand corrected! thanks
Old Apr 12, 2005 | 12:14 AM
SenSpeed's Avatar
Originally Posted by CKwik
None of my cross-drilled rotors on my previous car ever cracked. I went through 2 sets and tracked the car often. Not to say that cross-drilled rotors can not crack, but you have to look for specific features. Be weary of drilled rotors that have an abundance of holes. The advantage cross drilled rotors have over slotted rotors is that they allow pads to outgas when they overheat. When pads overheat, they start to vaporize and this creates a layer of gas trapped between the pad and the rotor. This is typically the first type of fade most drivers run into, evidenced by a stiff pedal, but necessitating more force on the pedal to get the car to stop as effectively. slotted rotors can do very little to vent air. If this is such a problem that you need to add a lot of cross-drilling, then you need to reevaluate your pads and the rotor mass. Make sure the holes are drilled between the vains of the rotor and not just randomly. This can prevent structural problems. Also look for spiral and offset drilling. They should be drilled so that they are not in a straight line from the center of the rotor. And if you were to trace a line along the arc of any of the holes, ever other set of holes should be along the same arc. Lastly, you want to make sure the holes are radiused. Cracking in any metal occurs at sharp points(corners). Radiusing the holes will reduce the chances of a crack starting at a hole in the the rotor's surface(where the heat is always highest).
My last car used Cross-drilled rotors sold by Stillen. They had all of these traits. It should be important to mention that it was a 240sx running on 300ZX brakes. Running large enough brakes are very important to any rotor. I would never use cross-drilling as a fix for any braking problem. Below is a photos of the rotors I used:
http://www.stillen.com/product_images/NIS3000_f.jpg
Notice there is only one hole per rotor vane and located between the vanes. The radius pattern for each set of holes alternate. Each hole is radiused. I would avoid rotors with a drill pattern like this:
http://neons.org/howtos/njne-kvr/show-kvr.jpg
It's more aking to perforation. Amazingly enough, I've seen a lot of porsche rotors with this type of pattern. It probably works out since porcshe tends to use rather large brakes on their cars so heat is less of an issue, but I find it pretty suspect myself.
nice response!
Old Apr 12, 2005 | 06:16 AM
neffster's Avatar
Thanks Ed. You just helped me decide on getting BOTH cross-drilled and slotted rotors for my next purchase. They look good; I won't be tracking the G, no cracking for street use only applications... I'm now content.
Since Brembo seems to only make either cross-drilled or slotted rotors (I don't see a combo) is there another rotor that either you or CK would recommend that will work with the stock Brembo Calipers that is both cross-drilled AND slotted? Also, maybe you could recommend a low dusting yet performance effective brake pad that would be a nice compliment to the rotors. I don't want a pad that's too hard and chews up my nice rotors.
Finally, the Project MU is out of the question for me. That hideous blue/green color just won't work w/ my G.
Kelvin Style006
May 23, 2016 03:47 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
