Filling Gas
Old Apr 17, 2005 | 07:22 PM
leegina's Avatar
Filling Gas
Anyone else have problems filling gas in this car? Today and it has happened in the past but not this bad. Anyway when I would stick the nozzle in and clicked the lever imediately it kicked off and continued doing this for about 20-25 times eventually it started spilling over down the side of the car. I needed gas so I knew it wasnt full or anything. But finally I got it to where it would accept the gas without clicking off. Is their a trick to this car or what? Thanks for any suggestions.
Old Apr 17, 2005 | 08:45 PM
leegina's Avatar
Wink
Should of used the search button!!!
Old Apr 17, 2005 | 10:31 PM
g35driver05's Avatar
Hey that happned to me to like a couple of time. not 20-25 times in a row like that.. It only happens to me at this one gastation. Does this happen to you at all gastations? Sometimes the hoses the use have air leaks in them and that will casue it to stop pumping.
Old Apr 17, 2005 | 11:31 PM
visualfusion's Avatar
Anyways, yeah, I've experienced this many times... but not in a row. To make sure that it wasn't just an error of the pump, I took my E320 there at the same pump and ... what do you know? No miss clicking! ... maybe there's something wrong with our gas tanks?
Old Apr 17, 2005 | 11:51 PM
cungkpham's Avatar
many times on my G... but the funny thing is that I use Shell and Chevron gas... and it only happens at Chevron...
the trick: have the nozzle out of the filler hole to the tank (where you can see the tip of the nozzle) and press the lever... Works for me.
Old Apr 18, 2005 | 01:16 AM
desi_pimp2002's Avatar
^ wat he said....when it does it...jsut lift ure nozzle up a bit till it stops doing it
Old Apr 18, 2005 | 02:44 AM
No1Better's Avatar
Should have...could have....would have...
sorry...
Old Apr 18, 2005 | 10:23 AM
Infinite1's Avatar
20 Year Member
Ditto on what he said....That happens a lot at the Chevron's
OH yeah and NO1.....i like the bottom of your sig kababyan....HAHAHAH!!!!
Old Apr 18, 2005 | 07:14 PM
SLVRG35's Avatar
Same thing was happening to me. I mentioned it the service rep while @ dealer and received a new tank today.
Old Apr 18, 2005 | 07:39 PM
pfizzle's Avatar
It happens to me all the time ... i never really said anything about it, but since this is the 3349865 thread about the gas tank issue I thought I minuswell comment.
Old Apr 19, 2005 | 01:02 AM
nate's Avatar
Some reading material:
How Things Work
Scientific analysis
Solution in simple terms
Pics from the last link show a possible simple explanation/solution -from last link (NY State Environment Govt related link)
I have not had the problem in many months so have not been able to validate this fix, but sounds legit and easy to try.
Old Apr 19, 2005 | 02:38 AM
No1Better's Avatar
Happened to me a couple of times at a Unocal but it's never happened again anywhere at all. Guys at the dealership told me that it could be the nozzle itself not detecting FULL INSERTION. So I make sure I stick it in all the way so it comes out properly...i can't stop laughing but this is the only way to explain this...BTW, I'm not a kid but I think like one!
Old Apr 19, 2005 | 03:52 AM
leegina's Avatar
Well this was at a chevron station!!!
Old Apr 19, 2005 | 09:29 AM
Black2003G's Avatar
This happens to me everytime i fill up. I can ride the yellow light for miles and still only get 13 gallons in. That gauge wont read full either. I just had my tank replaced about 5 weeks ago and the sender unit about 8. Going in on the 27th maybe i'll get a newer tank. Can this be classified as a lemon?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
