offset question
Old Apr 26, 2005 | 10:17 PM
prelude555's Avatar
offset question
hey guys i did a search but didnt get the answer i wanted. here it goes,
18x8 f 235/40/18 +38
18x9 r 265/40/18 +38
will i have an issue on rubbing with the offset this high? what can i expect with these rims on my 05 coupe. i plan on dropping it no more than 1 inch , thanx
Old Apr 26, 2005 | 11:40 PM
mmpotash's Avatar
Offset
I don't have an answer but I am possibly buying used non OEM rims to be used for winter tires on a 2005 G35 6sp coupe. They were bought by the seller from tirerack for a coupe.
The size of the rims, I think, is 17-8 with an offset of +35. The problem of fitment may be in the front wheel, which has a tire width of 235.The brakes are not a problem. The problem may be the strut clearance. I checked the difference compared to the 17" wheel of the 2004 coupe, and with the different offset, 30 vs 35, and the 10mm wider tire, the tire will be 16mm closer to the strut behind the tire. I've heard that the G35 OEM coupe wheels will fit the 2005, but I'm not sure. Does anyone have any insite on whether the 17-8 +35 will work on the 2005 6sd coupe?
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
