Navigation question
Old May 20, 2005 | 11:05 AM
rzaman's Avatar
Navigation question
I have a 2005 6mt coupe, and I'm pretty new the using the navigation. I had 2 questions. First, if for some reason I make a wrong turn following the directions, shouldn't it recalculate the route? With mine, it just kinda shows the whole route, and it wont start the directions until I get back on the route. The only way to fix it is to cancel it and restart the destination again from where I am. Also, is there any way to edit the address if I have it stored as the wrong street number for instance. Thanks for the help...
Old May 20, 2005 | 12:02 PM
rwdds's Avatar
Go to the Settings menu and select the Auto Reroute to ON. Should take care of your reluctant Nav system.
Old May 20, 2005 | 01:07 PM
Msedanman's Avatar
O.F. Administrator
Ya man, auto-Rer. must be on.
Enjoy.
C.
Old May 20, 2005 | 03:25 PM
Rno's Avatar
Rno
Look for "Auto-reroute" in your owner's manual.
--Rno
Old May 20, 2005 | 03:42 PM
TimF's Avatar
I also find that even though it auto-reroutes, it does it based on the the original route. This is fine if you actually make a wrong turn, but very annoying when you want to take a different road because you know it is better in real-life. You can have the Nav do a full recalc by ressing the 'ROUTE' button, scroll down to 'Edit Route' on the screen, select 'Route Calc' and then select 'OK'. This will recalc th route based on your current location as opposed to the starting location.
Plur
Interior
May 22, 2019 04:35 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
