Stale Air Smell Coming From A/C Vents.
Old Jun 13, 2005 | 03:59 PM
BlackonBlackG35's Avatar
When I turn on the A/C, there's a stale air or water smell coming from the vents. It only last a few minutes or I just get used to the smell.
Anyone else have this problem? Will it eventually go away or will I have to have it serviced.
I have the Stillen HiFlo Airbox installed. Could this be the problem?
Old Jun 13, 2005 | 04:04 PM
GT-Ron's Avatar
The culprit usually seems to be the in-cabin micro-filter. They get sour-smelling when they get too dirty...
...Also, I've noticed always using the recirculate button tends to make this worse (or happen faster). It's not limited to this car. Seems like nearly every new car with an in-cabin micro-filter develops this over time.
Old Jun 13, 2005 | 04:08 PM
Andy77's Avatar
I agree with the recirc button answer. If it used often, the moist air doesn't get removed and have the water taken out. I don't know, yet!, about the filter-only 9 months and 7500 miles.
Old Jun 13, 2005 | 04:20 PM
oh ok, I didnt know that. I only use the recirculate mode!
You say it develops over time, my car only has 4000 miles. Also can I clean or replace the filter myself, or does it need to be done by a professional?
Old Jun 13, 2005 | 04:22 PM
Pwoz's Avatar
Do you run the air on the lowest speed a lot? I was told that could cause it cause it was happening to me. I started running it on 2 or 3 now and the smell isn't there when I first start up the car.
GT-Ron's Avatar
I'm with you on the cause for the smell (recirc.). I think it just manifests in the filter because it holds all that moisture. It's a very distinct funk, isn't it?!
Old Jun 13, 2005 | 05:47 PM
P_Diddy's Avatar
There is a new TSB on this. https://g35driver.com/forums/showthread.php?p=599255
Old Jun 13, 2005 | 09:37 PM
Andy77's Avatar
When set on Auto, I think the recirc only comes on at the start when the car is very hot. I think it then switches to outside air. I didn't notice recirc coming on until it got very hot here.
As in the other thread I cited above, I never push recirc myself, unless I am in a really smelly air situation-ie following a garbage truck or the like. I tend to forget I pushed it for a while. When it is in recirc, most of the air is from inside the cabin-that is, moist (from your breathing too). The system doesn't get to dry out. Try running it cool without recirc.
Old Jun 14, 2005 | 02:46 PM
pioneerdat's Avatar
re: Stale air smell from AC vents
I had the dealer change the filter at my 15K service. Didn't have the smell for about 3 weeks with the AC on. The the smell started up again. Found that I could eliminate most of the odor de socks if I click on the outside air button while using the AC, then just run the fan (w/o AC) for about 3 minutes before shutting down the engine. I would suspect that a portable ionizer would help get rid of the mold-I've got one on order.
champppy
Mar 31, 2020 12:25 PM
Gip
Aug 24, 2015 05:31 PM
newg37
Jul 26, 2015 09:32 AM
justgotg35
Jul 19, 2015 12:33 PM
