Plastic Engine Cover - what is the point?
Old Jun 25, 2005 | 10:27 AM
MikeStarrG35's Avatar
Obsessive Owner
What is the point of this plastic engine cover that Infiniti puits over our engines. I toook it off and it looked a lot cooler in my opinion. Does anyone know if it is just to make the engine look neater? I would like to leave it off but i dont know if it has a mechanical purpose, like heat sheild or something. Just though I would ask and see what you guys think. I did a search but I didnt find anything.
-Mike
Old Jun 25, 2005 | 10:57 AM
escobar929's Avatar
just for looks, just bought CF cover for a 350z, but i'm returning it since it doesnt fit w/ the crawford plenum.
Old Jun 25, 2005 | 11:06 AM
mario24601's Avatar
its to make it look pretty
Old Jun 25, 2005 | 11:23 AM
glennp_1999's Avatar
I took mine off cause the plenum spacer I got was to tall and now it wont fit. It's been of for a while and I don't see any difference.
Old Jun 25, 2005 | 01:23 PM
Msedanman's Avatar
O.F. Administrator
-Mike
Yes it's a pain but besides helping to keep the underside clean and protected, it aids in air flow to give optimum coefficient of drag.
C.
Old Jun 25, 2005 | 04:04 PM
S2020's Avatar
C.
are you serious? I figure with the hood closed there'd be no difference
Old Jun 25, 2005 | 04:10 PM
Msedanman's Avatar
O.F. Administrator
Very serious.......the flatter and smoother you can make the underside of the car the better the aerodynamics, hence the better the handling ..............really.....
C.
Old Jun 25, 2005 | 04:12 PM
sarcasmo's Avatar
C.
Sure. It also protects the HID coolant reservior from the engine heat.
Old Jun 25, 2005 | 04:18 PM
TheCutter's Avatar
C.
Actually, since taking mine off, I have noticed approximately 26hp gains on the dyno. This is secondary to the improved cooling of the engine without the plastic cover.
Unfortunately, my scanner is broken, so I can't post my dyno results...
Old Jun 25, 2005 | 04:33 PM
Msedanman's Avatar
O.F. Administrator
Right.....Right. uhuh.
Old Jun 25, 2005 | 04:37 PM
G8RDave's Avatar
GSM, I think you are referring to the wrong part. The original question referred to the plastic cover on the top of our plenum, not the plastic cover underneath the engine.
Old Jun 25, 2005 | 04:44 PM
Msedanman's Avatar
O.F. Administrator
You're right Dave (TNX), I misread the post....my bad guys. The top cover is just dressup, and leaving it off will definitely help cooling.
-----now where the h*ll did I leave my glasses.....
C.
Old Jun 25, 2005 | 04:53 PM
auto_drive's Avatar
ahh, ic ic.
*goes and takes it out of his car* haha
Old Jun 25, 2005 | 05:05 PM
S-Tuned's Avatar
gtr proto test driver
learn something new everyday.
Old Jun 25, 2005 | 05:12 PM
lowrider's Avatar
I like the darn thing. I modified mine to fit my Crawford plenum. I think it finishes off the engine nicely.
Note: These photos were taken before I put on my JDM right side battery cover.
Lou
Attached Thumbnails Plastic Engine Cover - what is the point?-plenum-04.jpg   Plastic Engine Cover - what is the point?-plenum-02.jpg
