throttle body upgrade?
Old Jul 4, 2005 | 12:05 AM
bverschage's Avatar
has anyone done a throttle body upgrade? if so which one, and was it worth it?
Old Jul 4, 2005 | 07:47 AM
Q45tech's Avatar
Just like its MAF, Nissan designs for minimal TB restriction at WOT max rpms.
Typical restrictions run less than 7" water column...........1/4 of a psi for each. [[NOT 100% additive]]. Unlikely that the entire air tract from outside thru everything to plenum has even 14" water column restriction.
For the past 8 years, manufacturers have utilized the 25" water column standard as this is what is used on a flow bench to measure the cylinder head restrictions.
Gaining a HP or 2 might be achievable at the risk of some downside in transistional smoothness or fuel mileage at the optimized 55-65 mph range [due to changed resonances in intake tract].
Drive by wire TB are expensive and finely tuned pieces of equipment.
Old Jul 4, 2005 | 07:25 PM
bverschage's Avatar
q45tech
thanks for the info
Old Jul 4, 2005 | 08:57 PM
csdstudio's Avatar
LOL. For people who don't know exactly what language you're speaking, sure sounds friggen hilarious. I know you know what your talking about though, that's what matters.
Old Jul 5, 2005 | 07:52 AM
neffster's Avatar
For those that need help understanding may I suggest this web site
Glad to see you back around and posting again Q45tech.
The man loves his manometers!
Old Jul 5, 2005 | 11:44 AM
Deang35c6's Avatar
350EVO offers a bored out OEM TB, but I would personally try to ECU from Technosquare as the problem is not with the TB, but with it closing prematurely towards redline.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
