Gas Tank/Fuel Gauge and Service Bulletin 05031
Has anyone had this done and did they complete it successfully without screwing up your back seat or anything else? Any fuel smell afterward? Did you take it in with an empty tank? Any problems after the fix?
Had this particular TSB fixed last week. It was a definitive fix. No problems thus far nor do I anticipate any. Service tech asked that the gas tank be about 1/4 full. He said that it would be easier for him to drain and refill. I had a 1/2 tank of gas in my G. I told him I was sorry about the fuel level, but I told him he could put my fuel into his car . . . Just get it fixed!!!!!
Originally Posted by GGGunit35
Whats this problem?
http://www.infinitihelp.com/Ownershi.../ITB05-031.htm
Also, my fuel gauge registers empty and the warning light comes on but the most gas it will ever take is about 13 gallons. If I work at it, I can get it all the way full. Will this fix also take care of this or is this the gauge sending unit or something else? I've asked the dealer about it and they said they've only had three or so with this problem however I find it hard to believe since I read so many complaints about it here.
If you have a difficult time filling your tank due to the shutter valve issue . . . Have it changed now. That may or may not be related to your other issues(s). Just a thought. Good luck!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Hogbone
Sep 28, 2015 06:44 PM
