how do you mount mikes radar mount
Old Jul 28, 2005 | 12:50 AM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
how do you mount mikes radar mount to rearveiw mirror
I have new escort cordless solo s2
need step bye step?
thanks
Old Jul 28, 2005 | 03:45 AM
achen's Avatar
need step bye step?
thanks
Hmm.. I don't know if your radar detector mounts the same as mine. I have the 8500 x50 with mike's mount. You pretty much take the amount apart, and stick the metal piece that usually connects the radar to the suction cups in between the two plates of the mount. Then you retighten the mount and the metal thing should be held in between. Then you bend the metal piece a little so you can put the radar on and make sure it's level. To mount it to the rearview, you take the two acorn nuts off the top and just put your rearview between the two pieces. I'm not sure if I described it exactly correct but I'm doing my best from memory. It was a pain in the a$$ to get it in the perfect position so I don't want to go out there and take it apart to look at it. I pretty much just figured it out myself by looking at the mount so it shouldn't be too hard to throw together.
Old Jul 28, 2005 | 05:57 AM
speedygp's Avatar
Wink
need step bye step?
thanks
I have the V1 mount from mike, and I love it! Very clean looking and secure attached !!!
Old Jul 28, 2005 | 07:48 AM
LUV2DRIVEMYG35's Avatar
need step bye step?
thanks
If it's the one that I just bought that attaches to the rear view mirror stem I may be able to help cause I have the same detector.
You need to take the suction cups off the metal bracket. Then you'll need to slowly and carefully bend the bracket so that the tongue that slides on to the top of the solo2 is parallel to the car although the bracket comes down at an angle. If you don't do this, then your detector will be facing the right front tire. I found the best way to do this was to be inside the car, and slide the bracket into the radar mount w/o screwing it and position the radar mount so you can get an idea of how much you have to bend. Then bend with a towel wraped around the tongue using channel locks. Once you have it bent, then slide the bracket through the slot on the bottom of the plastic and tighten the screws. Next, secure the radar mount on the RVM stem. Get the acorn nut screws reasonably tight by hand, but not really tight because you may have to take it off to rebend the tongue if the detector isn't flat and straight.
Lastly, slide the solo2 on the tongue as best as possible, then fit your finger behind the RVM, depress the tongue release button and slide the solo2 in the rest of the way. Check to see how flat and straight the detector is. The tolerance is close but you can get it so that when the solo2 sits flat (level to the ground) that the top of it is just touching the bottom of the RVM. Check for straightness (parallelness to the car). If good then tighten the acorn nuts to firmly secure the mount to the RVM stem. The best way I found to do it is this is to get a socket (but not the wrench), and place the socket over the acorn nut and turn the socket by hand. The socket gives you more gripping area to turn.
Repeat the procedure until you have the mount the way you want it.
Good luck.
Old Jul 28, 2005 | 09:14 AM
snelldogg's Avatar
Who is Mike? and how do I get more information about this mounting system?
Old Jul 28, 2005 | 03:37 PM
6969g35's Avatar
need some pics of mount to solo s2
thanks
Old Jul 28, 2005 | 03:47 PM
achen's Avatar
Luv2drivemyg35 gave a very good explanation on how to set up the mount. I think that's exactly how I did it except I didn't use tools. I'm going to go tighten the nuts right now with a socket since that was a good idea
Just do a search for "mike radar mount" on my350z.com/forum and it should come up. He makes custom radar mounts for Zs and Gs and sells them for 20$ via paypal.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
Claudiu
Sep 24, 2015 01:12 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
