Wire Colors & Locations
Old Aug 14, 2005 | 05:11 PM
1SIKH22's Avatar
this os for 05 coupe, but should be very similar on all coups
12volts white/blue (40A) + ignition harness
Starter white/red or red/white + ignition harness
Second Starter white/green + ignition harness
Ignition black/red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory white/black + ignition harness
Second Accessory N/A
Keysense black/pink + ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is in the driver kick panel.
Power Lock yellow - driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock lt. blue (double pulse) - driver door module in door
Lock Motor purple 5wi BCM, pin 50
Unlock Motor yellow 5wi BCM, pin 44
Parking Lights+ red/blue + driver kick, harness to rear
Parking Lights- N/A
Hazards green/red - hazard switch or BCM, pin 29
Turn Signal(L) green/white + BCM, pin 45
Turn Signal(R) purple/white + BCM, pin 46
Reverse Light purple or red + driver kick, harness to rear
Door Trigger yellow (D), pink (P) - BCM, pins 62 and 12
Notes: Use both wires and diode isolate each.
Dome Supervision purple/red - BCM, pin 48
The step lamps are yellow/purple (-) at the BCM, pin 47.
Trunk/Hatch Pin red - BCM, pin 57
Hood Pin lt. green/black - hood pin switch under hood
Trunk/Hatch Release pink - BCM, pin 30
The trunk release motor wire is green/white (+) at the BCM, pin 68.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT white/blue or black ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire pink/blue + brake pedal switch
Parking Brake lt. green/black or purple/red - parking brake switch
Horn Trigger green/black - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
