Front Lip Question !!!
Old Aug 20, 2005 | 02:45 AM
driftGT350's Avatar
Hey guys! I got a question, how much of the front bumper does a lip cover, thanks!
Old Aug 20, 2005 | 08:21 AM
Jtrain's Avatar
It doesn't really cover any of it, It prolly makes your clearence a inch less or so
(old pic, puttin up clear corner pics later today)
Old Aug 20, 2005 | 01:11 PM
chicagokid's Avatar
Jtrain-
Is that OEM lip? Did you install yourself? I am getting one (OEM), but unsure if I have drill holes or use 3M double sided tape or both????
Thanks....
Old Aug 20, 2005 | 02:19 PM
Finiti35's Avatar
FGC South Florida BOD
The front lip comes with detailed instructions, and yes you will have to drill about 5-6 holes or so...
Old Aug 20, 2005 | 03:38 PM
cotmfk's Avatar
I recommend it. It definitely helps to give the G's front end an edge!
Old Aug 20, 2005 | 05:21 PM
Z2G's Avatar
Z2G
actually, i don't think it gives you less clearance. it appears to end right at where the oem bumper ends. i installed it myself on my coupe and found no difference.
Old Aug 21, 2005 | 01:06 AM
Andy2434's Avatar
I have been thinking about getting the OEM front lip. I am concerned about the clearance issue. Perhaps it's not as bad, as I thought it might be.
Old Aug 21, 2005 | 01:14 AM
Gee Im Fast's Avatar
Agreed and I even speculated this without ever seeing it installed (came ordered like that for me)....if anything, it makes the car look like it has a higher clearance...
Old Aug 21, 2005 | 01:22 AM
Andy2434's Avatar
Looks like a new OEM front chin spoiler is in the very near future for my G.
Old Aug 21, 2005 | 01:27 AM
Finiti35's Avatar
That is correct, I have compared mine next to another 05 and it doesn't give you less clearance.
Old Aug 21, 2005 | 03:52 PM
chicagokid's Avatar
Do I drill holes on the bumper (lower/bottom) or frame????
Thx...
Old Aug 23, 2005 | 02:47 AM
Z2G's Avatar
Z2G
you have to drill the holes into the bumper. you may want to follow the instructions and to the underside holes too for extra security. there have been a couple members who have had their front lip ripped off by parking dividers. they didn't install the underside clips on their front lip spoiler.
Old Aug 23, 2005 | 03:11 AM
chicagokid's Avatar
Perfect... that's what I needed to know. Thanks man.
Old Aug 23, 2005 | 08:45 AM
maxpower's Avatar
how does the paint hold up on the lip? do you get numerous rock chips? thanks for any feedback
Old Aug 23, 2005 | 12:10 PM
hayaku's Avatar
Good question. I hope the paint holds, since I just installed the front lip last nite. Oh and by the way, after spending a few hours under the car fussing with all the fasteners, I can tell you that the front lip only adds about 1/4 inch less of clearance. Pretty much the thickness of the plastic is what is below the front bumper. That little 1 inch tall air dam thing under the bumper sits lower than the lip. If you don't have problems scraping with that, then you won't scrape with the lip.
