Excessive valve lash
Old Sep 3, 2005 | 03:58 AM
G35DDS's Avatar
05 Coupe A/T 7500 miles
Has anyone experienced valve lash noise when driving especially when excellerating? I checked the oil and its fine. What could it be?
Old Sep 3, 2005 | 05:36 AM
glennp_1999's Avatar
What do you mean by valve lash?
Old Sep 3, 2005 | 08:33 AM
EricIsKlumzyee's Avatar
whats valve lash noise?? o.o isnt valve lash the clearence between the valve stem and lifter? u only have 8k miles..
more details please
BracketRacerSteve's Avatar
yeah, what is valve lash??
do you mean knocking/pinging?
if so, run 93 octane
Old Sep 3, 2005 | 08:58 AM
G35DDS's Avatar
I only use 93 octane. The noise is from the rocker arms, you can hear the tap tap tap when you accelerate, the noise gone once you let off the gas.
The car has no engine mods, except for the Z tube and K&N but that cant be causing it. I agree that u shouldn't hear it on a car with 7500 miles but its there. It does not do it when the car is cold although I have only owned it for 6 months and have not gone through a NY winter yet.
Old Sep 3, 2005 | 09:11 AM
if it goes away then it shouldnt be a big deal (Something else??).. cause if it is a valve lash problem then wouldnt you ALWAYS hear it?.
- i have no idea what valve lash should should like btw >.<
Old Sep 3, 2005 | 09:34 AM
What kind of oil do you use? Sounds like you need an additive to help silence the lifters.
Old Sep 3, 2005 | 09:42 AM
G35DDS's Avatar
I use Mobil 1 5w 30
Old Sep 3, 2005 | 09:55 AM
DaveO's Avatar
It hard to troubleshoot an engine noise problem without hearing it yourself. My thoughts are that you may not have a valve lash problem. I'd recommend you vist your local friendly Infiniti dealer.
Your VQ35DE engine doesn't have rocker arms nor do most (all?) overhead cam engines. Nissan/Infiniti calls their cam followers "lifters". The clearances are normally between 0.012" and 0.017" depending on if the clearance is an intake/exhaust, is cold or hot and which year engine you have. Normally most if not all of the valve lash noise goes away once the engine reaches temperature and te clearances close up.
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
