just installed my intake but i have a little problem..PICS!!
Old Sep 14, 2005 | 01:25 AM
savefatkids's Avatar
i know where it is..
but is there a certain wire to unplug it?
Old Sep 14, 2005 | 01:31 AM
MikeyMike's Avatar
Rollin On Dubz
I bet you didn't plug the Mass air flow sensor back in.
Did you use a manual to install the intake? Go back over it with a fine tooth comb.
Old Sep 14, 2005 | 01:55 AM
04g35cNJ's Avatar
what a pain in the *** for +2 hp
Old Sep 14, 2005 | 02:06 AM
imalazeeass's Avatar
unplug the negative side
Old Sep 14, 2005 | 02:49 AM
lol thats what i said after i was done..but it sounds really nice and looks good too
Old Sep 14, 2005 | 04:24 AM
arjunz's Avatar
make sure ur MAF sensor is plugged in as many people said .. very important ... and cover that ac line ... or else u'll be without Air Condition in ur G.
Old Sep 14, 2005 | 06:14 AM
RashMan1450's Avatar
also make sure you didnt cut the MAF sensor wiring
Old Sep 15, 2005 | 12:29 AM
ok everything is fine..and i didnt need to uinplug the batter for 12 hours.... just unplugged it for 12 minites
Old Sep 15, 2005 | 12:31 AM
arjunz's Avatar
aight ... good luck .. how doe it sound btw
Old Sep 15, 2005 | 03:08 AM
borahatch's Avatar
Originally Posted by savefatkids
where is the ac line??
Check it out, I put this pic up so you could get the AC line covered ASAP. Hope this helps.
Old Sep 15, 2005 | 08:10 AM
cKy2k's Avatar
did you install your intake or did someone else ....
for someone not to know what the ac line is and not know how to disconnect a battery is in trouble ... get to know your car a little better ...
Old Sep 15, 2005 | 08:17 AM
UofMG35's Avatar
I'm sure this has been discussed before, but the intake that you put in has the air filter at the lower bumper opening. If you go through a big puddle, won't it suck the water into the engine... then you'd be screwed. Is the air that much colder down there than at the grill opening to risk this?
Old Sep 15, 2005 | 12:36 PM
ranks44's Avatar
Hey savefatkids - hope this helps - seems like sometimes it's hard to get answers here and that's because most stuff has already been explained so it helps to do a very good search! But with your intake I'm glad you got it to work - but you should still do the ecu reset. Everytime you add a mod you should reset - you should notice a difference. Do a search for ecu or battery disconnect and you'll see why and how. It takes most people a few times to get the timing down correctly. check out that pic to save your a/c line and you might want to think about covering your cone a little so not much water can get to it. Good luck
Old Sep 15, 2005 | 01:12 PM
nnkfws333's Avatar
You can get an AEM Air Bypass Valve to prevent hydrolocking
http://www.aempower.com/product_intake.asp?subCatID=3
but you have to have the filter totally submerged in water in order for that to happen but a little water here and there is fine.
Old Sep 15, 2005 | 03:51 PM
  #30
UofMG35's Avatar
Makes sense, thanks!
RA081024
Aug 18, 2015 07:03 AM
RA102223
Aug 15, 2015 09:24 PM
ghost_g35
Aug 7, 2015 10:31 AM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
