Arrrgh! This is finally happening to my g! Help?
Old Nov 1, 2005 | 02:14 PM
GFN-G35's Avatar
ok i have toe wear on my stock setup so dont worry about it your gonna have to deal with it our cars have lots of toe so it going to happen at some point. if your car is sitting at stock specs then there is nothing changed and your wear is due to normal wear and tare
Old Nov 1, 2005 | 03:24 PM
Aznteazer's Avatar
flip the tires around and they will last twice as long.
Old Nov 2, 2005 | 01:10 AM
Triple8Sol's Avatar
While you're upgrading your suspension, hurry and swap out your springs too. The Tein springs (both versions) for the G35c are no good...
Old Nov 2, 2005 | 11:11 AM
Deang35c6's Avatar
You don't need the entire rear camber arm, just the bolt. You can have a shop elongate the hole to adjust the camber and gain more room for proper adjustment. The only benefit of changing out the rear camber and toe arms is the for the polyurethane bushings. I have an extra SPC bolt set that I would sell to you. PM me.
Freeman186
Sep 6, 2023 10:07 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
douglas555
Sep 10, 2015 04:48 PM
