HELP!! Grille Install
Old Nov 2, 2005 | 05:16 PM
Jee_35's Avatar
Hey guys, I just got my SP grille in for the 05 G coupe. It's painted and ready to go... BUT I can't get the stock grille off. I removed the 6 "black plastic screwies thingies" but the top of the grille is still stuck on the corners. I can't figure out how to remove it. As for the bottom of the grille, there are these clips holding it in, but they too won't budge. Can anyone help me plz??????? Thanks!!
(I did do a search for a DIY but there were no results)
Old Nov 2, 2005 | 05:21 PM
crypten's Avatar
You have to push down a piece of the grill (small clip inside) on the upper corners. I used a small flat head screwdriver with some force to pull it off. Don't get nervous about using force, it feels like it's going to break off, but it won't break. Good luck.
Old Nov 2, 2005 | 05:24 PM
G-ThreeFizzle's Avatar
*dammit, you beat me to it ^
There is a DIY if you search in this section, but I'll just tell you how to do it anyways. Use a flathead screwdriver and you can stick it on the corners and turn counterclockwise, this will release the little plastic screw holding it in. The bottom portion you can just pull-off, just use a little force. Good luck!
Diesel1's Avatar
Moderator
You should not need force!!!!
IN the upper corners you will see a little slot that looks like a flat head would fit. Look into that slot and you will see a square screw head, turn that 1/4 turn on each side. Now, reach ur hand behind the grill, you will see several silver tabs sticking through. Go to each one and depress the tab (on the tab) and push out to releas the main tab. I think there are 4-6 of these that you need to repeat for each one. Grill should come off easily.
Old Nov 2, 2005 | 05:29 PM
crypten's Avatar
Jedi use the force. why can't we?
I used minimal force, and it popped off just fine. It did feel like it was going to break, but it didn't.
Old Nov 2, 2005 | 09:23 PM
hye_G's Avatar
hey guys since we are on the subject i thought id ask. i removed my grill to test fit my gialla and then i took it off to go get it painted and i tryed to put the OEM grill back on but it wouldnt sit as tight as it was b4 becuase of those damn little square clips i couldnt get back fitted in the grill. is there a trick to this?
Old Nov 2, 2005 | 10:47 PM
Diesel1's Avatar
Moderator
Gotta futz with em a bit. It may be easier to remove them from the car and install them in the grill first then put grill back in.
As far as using force, yes I did it that way the first time I removed mine, but Ducatiguy showed me the lil screws on the side that get a 1/4 turn. No chance in breaking the grill that way.
Old Nov 2, 2005 | 11:23 PM
I think he meant only using force to take out the bottom portion of the grill. The corner screws didn't require any force when using the screwdriver.
Old Nov 3, 2005 | 05:56 PM
Diesel1's Avatar
Moderator
Bottome portion should def not need force! You will break the cheap plastic tabs easily! With the hood open all you do is reach behind and squeeze the tab and she'll come right out!
Wow now that can be perverted!
Old Nov 3, 2005 | 06:00 PM
Brando's Avatar
Those bottom clips are holding from the bottom not the top....if that makes sense.....
Old Nov 3, 2005 | 07:53 PM
roko's Avatar
I always use painters tape, on the paint near the bottom of the grill so I don't scratch the paint when I remove the grill.
jsimonk
Dec 22, 2023 03:49 PM
zoop425
Mar 29, 2016 05:51 PM
discoswan
Feb 24, 2016 08:57 PM
rymian
Sep 9, 2015 08:03 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
