Coupe Going Back to Dealer - Anyone Else have These Problems?
Old Nov 7, 2005 | 08:08 PM
ck700sl's Avatar
Just wondering if anybody has dealt with any of these issues and if they ever got resolved. Thanks.
1) HVAC (Mode Doors) - When air flow is changed using the “mode” button, the mode doors make studdering creaking noise.
2) HVAC (Temperature) - Air vent temperature does not change when air temperature button is pressed. Ex. When temperature is raised from 60 degrees, the air will not start to get warmer until the inside temp display reaches around 85 degrees. It will only get hot when display reads 90. Similarly, when temperature is lowered from 90 degrees to 60 degrees, air temperature will not become cold for few minutes.
3) Clicking noises coming from rear wheels - at low speeds (below 5 mph). Occurs intermittently, sometimes when brakes are engaged.
Old Nov 7, 2005 | 09:06 PM
SooMighty's Avatar
i think i might have that rear clicking noise prob also. but i just thought it was since i put custom rims on. i always wondered what it was tho. let me know what they tell you about it.
Old Nov 7, 2005 | 09:09 PM
Jiwon's Avatar
It's Well-known problem. I had that problem for a few min and hasn't come back
yet, but lots people on board seems to have. Dealer should know and be able to
fix it for ya.
Old Nov 7, 2005 | 09:20 PM
Dieselnuts's Avatar
im taking mine to the dealer on friday for the axles. Its under warrenty, so why not. there is a TSB report on it, so it should be fixed no questions asked.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
NemesisGee
Aug 11, 2015 07:10 PM
apintojr
Jul 23, 2015 10:52 AM
Lsantana757
Jul 20, 2015 09:08 AM
