Refrigerant coolant refill
Old Nov 21, 2005 | 01:33 PM
plux79's Avatar
Hei guys,
I just checked all my fluids and noticed that the refrigerant coolant is almost finished, should I refill them or bring it to the dealer. If I am going to refill it, what kind and brand should I use? Thank you.
Old Nov 21, 2005 | 02:00 PM
brandon1978's Avatar
Originally Posted by plux79
refrigerant coolant
Never heard of that.
Old Nov 21, 2005 | 02:13 PM
Msedanman's Avatar
O.F. Administrator
Hei guys,
You mean your A/C refrigerant, or your engine coolant?
The dealer will have to refill the A/C regrigerant (after he finds the leak), but you can refill the overflow reservoir yourself, (with like colour antifreeze).
C.
Old Nov 21, 2005 | 02:20 PM
plux79's Avatar
I am sorry, what I mean is the AC coolant. So all i have to do is buy the same color coolant?
Old Nov 21, 2005 | 02:39 PM
TheKnite's Avatar
Antifreeze? Coolant?
How do you check your AC level? I think you're talking about your coolant, and nothing to do with your AC. Is your AC working or it doesn't? AC means Air Conditioner.
How cooling system works: http://auto.howstuffworks.com/cooling-system7.htm
Old Nov 21, 2005 | 02:40 PM
There is no AC coolant. I will assume since you mentioned that you checked the levels of all fluids that you are talking about coolant (aka antifreeze). This is the green liquid (in our cars) that transfers heat from the engine to the radiator.
If the overflow bottle is low, I would first check that the radiator is not low as well. On a COLD engine, unscrew the radiator cap. The fluid should be almost to the very top. If it isn't, take it to the dealer. Never open the radiator cap on a hot engine, the coolant is under pressure and very hot. If the level in the radiator checks out, then you can top off the overflow bottle. Just do not fill it past the max level. inifinit recommends a mixture of 50/50 Coolant to distilled water. Don't use tap water. Some places sell it already premixed for convenience.
Old Nov 21, 2005 | 05:12 PM
partyman66's Avatar
If you're losing engine coolant... you have a big problem.
That coolant is likely going somewhere that it shouldn't be. Possibly a blown head gasket, or worse yet... a crack in the block.
You should not be losing any significant amount of coolant in your car if your system is properly sealed with no leaks or mechanical problems.
MrIP35
Oct 25, 2015 11:13 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
