G35Driver - Infiniti G35 & G37 Forum Discussion (https://g35driver.com/forums/)
-   G35 Coupe V35 2003 - 07 (https://g35driver.com/forums/g35-coupe-v35-2003-07-14/)
-   -   New engine. How can I tell if it's correct (https://g35driver.com/forums/g35-coupe-v35-2003-07/75916-new-engine-how-can-i-tell-if-its-correct.html)
ast Nov 22, 2005 02:38 PM
I'm having a new engine dropped in my car next week at the dealer due to excessive oil consumption at 11,000 miles. Engine is a crate motor (long block). Here's my question. My car is a 05 MTcoupe 298hp. How do I know they are putting in the right engine and not the 280hp version? Are there any serial # I should check?
partyman66 Nov 22, 2005 02:58 PM
I would think that the wiring harness would probably be different for the 298 HP motor and that it definitely requires a different ECU(different redline, different speedlimiter, I'm sure the fuel mapping is different, etc).
I don't think they could very easily stick the 280 HP engine in your car without changing other stuff.
clinty Nov 22, 2005 04:06 PM
I believe the plenum design is different on the 05. I wouldn't know the differences though.
eldy Nov 22, 2005 04:12 PM
The 298 hp engines have shorter intake runners than the 280 hp flavor.
InTgr8r Nov 22, 2005 04:35 PM
Correct me if I'm wrong...
but with a long block, all the external equip. (plenums, manifolds etc)
are reused.
ast Nov 22, 2005 10:17 PM
I beleive you are correct. Sounds like if it fits all my external parts it has to be the correct motor. Thanks guys.
DaveO Nov 22, 2005 11:15 PM
The cam covers are different (smooth) on the 260/280/287hp engine.
PBFILMS Nov 22, 2005 11:51 PM
what is considered excees oil consumption? i am burning a quart every 1000 miles. dealer says its due to the engines tight tolerences. am I being bluffed?
dofu Nov 23, 2005 12:08 AM
Check the numbers.
ast Nov 23, 2005 04:12 PM
My engine was burning a quart every 1000 miles. That's way to much in between oil changes for a brand new vehicle. If the dealer tells you that's normal find another dealer. Do a search under oil consumption, you'll find some threads.
reggiek Nov 23, 2005 07:02 PM
I need to stop visiting this site. The more I visit, the more problems I see with the G35. All year I've been saving and planning to buy this car now I'm afraid they are not reliable cars. In the past I had a G20 and a J30...both reliable cars that gave years of reliable, trouble free driving. What gives with Infiniti? Newer cars should be better, not worse.
mooka Nov 23, 2005 07:21 PM
remember theres like 35000 G35 owners here. Your odds are excellent that your car will have no problems. You don't see the threads "Everything is fine with my car" because it's so damn boring!
RussB Nov 24, 2005 01:08 PM
tight tolerances lead to burning oil? :confused:
i've got 12,000 non-gentle miles on my car and it doesn't burn any oil. the dealer is screwing with you on that IMHO. Ford finds 1qt / 1000 miles acceptable, but this is not a ford.
InTgr8r Nov 24, 2005 02:01 PM
If it helps..
I have 32K on mine & don't add any oil at all between changes..
jinubob81 Nov 24, 2005 02:41 PM
when he said, "tight tolerances" did he mean that your engine was not within those "tight tolerances"? Cause that would be a good reason why you're burning a quart every 1000 miles.
© 2026 MH Sub I, LLC dba Internet Brands
