help!!..winter setup wheels problem
I just bought a set of winter wheels/tires setup from an old man which previously was used on his 2003 coupe. Tried to put them on 05 today and I had a hard time fitting it. Does anyone know the setup for 2003 should fit for 2005?..I need to get this done soon before the snow falling down here in Boston. Thanks for any response!
I found out there are 6 pattern bolts on the front wheels. is that 6th bolt what they call the tire sensor? If so, what should I do to get it fit with my 17" aftermarket wheels?..please help
Originally Posted by jeremyp111
You need to take out that bolt. It's there for OEM wheels so you don't put the rears on the fronts.
Originally Posted by digital_nrg
will there be any harm to take that off and HOW to take it off?
C.
bu villain
19 Inch
Nov 15, 2015 09:23 PM
