Idle RPM
Old Feb 8, 2007 | 06:59 PM
bull3t's Avatar
i had this problem...it's due to a dirty throttle body most likely...it can also be a dirty maf
Old Feb 8, 2007 | 08:10 PM
mwarsh1's Avatar
Clean The Mass Air Flow, Should Help!
Old Feb 8, 2007 | 10:42 PM
BW350GTskyline's Avatar
i idle at 300 with ac on...
Old Feb 8, 2007 | 11:04 PM
griff87e's Avatar
When i first turn mine on, its idles at almost 2000rpms, and slowly drops down. I know its a cold start, but i'm in florida, it doens't get that cold. I heard its normal, but still seems old to me
How do u clean the MAF?
Old Feb 8, 2007 | 11:08 PM
GreenGoblin's Avatar
The goblin resurrection
you buy some maf sensor cleaner then take it off and spray the crap out of it
Old Feb 8, 2007 | 11:36 PM
BadBoy06's Avatar
Originally Posted by arjunz
mine drops to about 200-250 as well.... i thought it was normal
get it looked at..not normal
Old Feb 9, 2007 | 01:37 AM
Fiveseven's Avatar
my problem is a little different.. my car idles fine when staying still but when i drive and stop at a light the idle will dip down to 500rpm.. or lower.. car feels like its going to stall but it hasnt yet.. (6mt) im hoping its a dirty TB.. would the dealer do this for free?
Old Feb 10, 2007 | 03:11 AM
Fiveseven's Avatar
problem fixed.. dealer cleaned my TB.. costed me 120$ then reset my idle
Old Feb 10, 2007 | 10:41 AM
EX-250's Avatar
My G is set to idle at 850 rpms. 600 rpms = stall
Old Feb 10, 2007 | 12:25 PM
Joshua's Avatar
its normal....
Old Feb 10, 2007 | 12:40 PM
Nismo G's Avatar
Mine is usually around 600-750 RPMS. I have had it dip off to about 50 RPMs for a milisecond accords to my digital rpm guage
-sean
Old Feb 10, 2007 | 12:50 PM
Nismo G's Avatar
Also, i have found that the tachometer on the G is miss calibrated or somethings...its not very exact. Its about 200 RPMS off usually. I have a digital tachometer guage and i trust it more than i do the stock guage...
-sean
Old Feb 10, 2007 | 05:50 PM
EX-250's Avatar
-sean
Thats why theyre called gauges and not instruments. All tachs will be slightly off. According to my tach, I idle @ almost 1000 rpms, even though its set to idle @ 850 rpms. This small variation at that low of rpms can translate to a few hundred off by redline. To be honest, the G-tech RR (when its actually calibrated properly) seems to be better at gauging rpms than the oem tach... lol
Old Feb 10, 2007 | 05:52 PM
  #30
speedracerg35's Avatar
no way in the world your car is idling at 200-250 rpm.
