Rear pads uneven wear @ 38,000?
Old Dec 17, 2005 | 03:13 AM
totondee77's Avatar
Have the OEM brembo set up 38,000 mi, changed out the rear to the hawk hps, but the passenger side has wore down to the bone. It Did a number on the inside of the rotor. Has anyone experienced this? Would it be a good idea to bleed the system? I noticed that when i changed the front at 36,000 that the passenger side was also worn down more than the driver side. I didnt think that the rear was going to need to be replaced so soon after the fronts. Any suggestions. Posted pics
Attached Thumbnails Rear pads uneven wear @ 38,000?-dsc01610.jpg   Rear pads uneven wear @ 38,000?-dsc01611.jpg   Rear pads uneven wear @ 38,000?-dsc01612.jpg
Old Dec 17, 2005 | 08:02 AM
g35rcr's Avatar
i would bleed just because you have it apart anyways and put in better brake fluid like motul
Old Dec 17, 2005 | 12:57 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I sure hope you replaced that rotor that got ate up by the pad that went metal to metal...
-GP-
Old Dec 17, 2005 | 01:52 PM
RBull's Avatar
Rated M
Have the brakes looked at since something wrong caused the unusual wear. You'll likely have to replace that rotor and have the caliper repaired if it was partially seized causing the pad/rotor wear.
rezendvous420
May 31, 2020 01:26 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
miata007
Aug 17, 2015 04:36 PM
