Fx 45 Throttle Body in G35 6Mt
Old Jan 2, 2006 | 08:52 PM
zpeedray's Avatar
Have some body do this swap, i read somewhere here that is alredy done, corret me if im wrong.
Old Jan 2, 2006 | 10:59 PM
MechEE's Avatar
Worthless, save your money. I'm assuming it's a slightly larger diameter? Increasing the diameter of one of your 1-2" long pipes by a fraction of an inch is going to do nothing for you. If there's something else attractive about it, please share.
Old Jan 2, 2006 | 11:59 PM
badtziscool's Avatar
How big is the TB in the G? TBs aren't generally a bottleneck in a relatively stock engine.
Old Jan 3, 2006 | 09:53 AM
1BADV6's Avatar
Depends on diameter. Give us both and lets see.
I'm not sure the amount of gain for the money on stock engines, but this would be a great mod for forced guys.
Old Jan 3, 2006 | 10:29 AM
Mark350GT's Avatar
post up if there are any gains for us FI guys.
Old Jan 3, 2006 | 12:10 PM
MechEE's Avatar
Still not a great mod.
Old Jan 3, 2006 | 12:54 PM
1BADV6's Avatar
OK thanks .
So can anyone post the numbers or what?
Old Jan 3, 2006 | 01:00 PM
alexchuang's Avatar
throttle body upgrades arent worth it unless you are pushing 600-700 horses... how i know? i own a supra with 500 horses... stock throttle body... opening up your throttle body by 1mm is not going to make a difference in flow characteristics unless you go mega-horsepower crazy with the VQ
Old Jan 3, 2006 | 03:06 PM
1BADV6's Avatar
VQ35DE size is either 70mm or 75mm--can't find a straight answer on that.
The 4.5 V8 size is 90mm, and should be drive by wire as well.
Old Jan 3, 2006 | 03:07 PM
1BADV6's Avatar
Curious: what size is the TB stock in that Supra?
Old Jan 3, 2006 | 03:10 PM
Slick 6MT's Avatar
This thread is completely worthless without numbers ...
Old Jan 3, 2006 | 03:25 PM
madchef's Avatar
Several Max owners threw a pathfinder throttle body in their cars....IIRC there wasn't much of a performance increase, and it was really expensive.
Old Jan 3, 2006 | 04:21 PM
1BADV6's Avatar
Well yeah...70mm or 75 mm on a stock to well modified VQ is not going to yield anything. The 90mm is just giant.
Old Jan 3, 2006 | 04:42 PM
If the TB is 70-75mm, then that's plenty for any setup. 65mm is enough for 400hp.
Damn. Why does the FX45 use a 90mm TB? That's just overkill.
Old Jan 3, 2006 | 06:28 PM
partyman66's Avatar
Maybe the engineers felt that a big pipe in the engine would help offset the feeling of inadequacy in that of some of their drivers?
