Oil drain plug swivel valve?
Old Feb 24, 2006 | 12:13 PM
Sidewy8's Avatar
Anyone changed their drain plug to the swivel valve type? It would be so much easier and cleaner to drain the oil. Just connect a hose of some kind to the valve, switch the lever and have it drain to your catch pan. (Ideal process).
I want to do this but not sure if it will drain all the crap out and if the lever would ever get swithed if hit by a rock or something while driving. There goes the motor. But the cover tray should prevent that, right?
Similar to this. http://www.fumotovalve.com/
Old Feb 24, 2006 | 12:46 PM
Slick 6MT's Avatar
I remember hearing good things about these a while ago. I never got around to ordering one though.
Old Feb 24, 2006 | 12:49 PM
willthethrill's Avatar
i have it on my G. I love it so much i bought one for my truck. I bought the valve with the nipple. I hook up a length of hose (which i bought at the local hardware store) open the valve and drain right into the container. No mess whatsoever and have never had a problem with it. Also to open the valve you need to push it down then across and with a tiny bit of force, nothing a pebble could do...unless it was a magic pebble.
Old Feb 24, 2006 | 03:16 PM
G35MC's Avatar
not sure if it's as tight as the OEM drain plugs.
Old Feb 24, 2006 | 10:31 PM
Why wouldn't it be? I have had mine in my coupe for 2 years and one in my truck for a year. No problems.
Old Feb 25, 2006 | 12:18 AM
gizsf's Avatar
You could use the supplied gasket and torque it down...walaaah!
.....now if they could only figure out and easier way to change the oil filter
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
UT G35
Sep 3, 2015 03:58 PM
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
