Request: DIY for aiming 06' low beams
Old Mar 6, 2006 | 09:06 PM
haze's Avatar
I tried searching, but couldn't find a DIY. Can somebody please point me to the right direction?
Thanks a lot.
Old Mar 7, 2006 | 04:10 AM
OOOOA3's Avatar
Alumni****
how come you need to aim your 06 low beams. if you haven't messed with your stock low beams, then you should be fine.
Old Mar 7, 2006 | 04:16 AM
haze's Avatar
first of all, i, along with a few other members who mentioned the same thing a while back, think the stock low beam aims slightly too low. however, it is not too far off and is totally livable.
My g is lowered with springs, and the front is lower than the rear, and I think that contributed to the low beams aiming even lower.
Old Mar 7, 2006 | 10:15 AM
DjGenuine's Avatar
Yeah...my low beam lights are a bit low too. When Im behind a car it barely touched the back bumper.
Any info would help to adjust them just a bit higher.
Old Mar 7, 2006 | 11:31 AM
Sportcoupe35's Avatar
Same situation with me.
Lowered...car.
And now the beams are too low...I want to raise them just a hair.
Old Mar 7, 2006 | 02:46 PM
PhxBlue's Avatar
Polyester Pileup FTW!
Look at the back of your headlights. You will see a silverish colored screw. Take a very short 8mm socket wrench to it in order to adjust the up down height.
Old Mar 7, 2006 | 03:47 PM
OOOOA3's Avatar
Alumni****
sorry about that guys. didn't know the 06s had issues coming from stock. when i had the 06 headlights installed, they were a bit low and i adjusted them as well. PhxBlue's got the solution for you guys.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Jon81035
Sep 16, 2015 04:58 PM
twentyeggs
Sep 11, 2015 03:58 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
Jnm07
Sep 5, 2015 01:16 AM
