Dual wall tips or Single?
Old Mar 19, 2006 | 10:55 PM
gary c's Avatar
Once more............
I was just in my garage looking at my new cat-back
system from Magnaflow. The tips are dual and huge
and unlike my Borla system the muffler is highly
polished. Even if Magnaflow doesn't sound better
(and it should) it will look soooo bitchen!
Old Mar 19, 2006 | 11:01 PM
ShAdY908's Avatar
I too would like to know what is the difference between single and dual I know it looks different but any other differences?
Old Mar 19, 2006 | 11:51 PM
infg35's Avatar
Back Pressure
I have read that some systems loose too much back pressure? Is this true and if so which system looses the least ?
Old Mar 20, 2006 | 03:10 AM
jim5437's Avatar
I will go install that on Thursday,
I think Dual and Single wall tips are the same in preformance.
Just look different.
I like to see more clear pictures.
make it closer to the tip ok~
Thanks
Old Mar 20, 2006 | 09:44 AM
HansMoleman's Avatar
by dual wall do you mean like these... where there is an inner and outer pipe?
(Obviously not a G35)
If you are running any kind of cat you dont have to worry about back pressure.
Old Mar 20, 2006 | 11:41 AM
gary c's Avatar
Regardless of which system you purchase if it's made
for the G you shouldn't be concerned. Most are 21/2"
pipe and will work fine with your car. The main
diffrence is if you go FI you'll "NEED" a 2 1/2" dual
system not really needed with normal operation.
And, for those of you looking for an example of dual
or single wall tips look in your Stillen catalog on
page 12. Its in living color...............
Old Mar 20, 2006 | 12:21 PM
fijbert's Avatar
+1
anyone care to explain?
Old Mar 20, 2006 | 04:18 PM
I dont have a stillen catalog why would i?
a picture would also help.
emoticons are fun.
Old Mar 20, 2006 | 04:27 PM
KccBaby's Avatar
explained in words already...dual WALL tips...what does wall mean? The side around the tips...tips tips tips...all about tips...
___________________________
\_________________________ (Dual)
__________________________ (Singal)
something like that... :P
Old Mar 20, 2006 | 04:36 PM
prog35's Avatar
These are dual wall tips from my old Altima.
Old Mar 20, 2006 | 04:44 PM
prog35's Avatar
This is a single wall tip
Old Mar 20, 2006 | 09:14 PM
chops's Avatar
Here you go (Stillen single)
Old Mar 21, 2006 | 01:38 AM
jim5437's Avatar
Thanks guys, those really helped,
jim5437's Avatar
[QUOTE=prog35]These are dual wall tips from my old Altima.
Is there something inside the tips?
I saw another pipe there~
Will G35 have that inside the dual wall tip?
Old Mar 21, 2006 | 12:19 PM
  #30
GeeMan's Avatar
This might help. Enlarge.
Attached Thumbnails Dual wall tips or Single?-stillen-single-wall.jpg   Dual wall tips or Single?-stillen-dual-wall.jpg
