Alignment Questions?
Old Mar 19, 2006 | 09:02 PM
Sam Siador's Avatar
OK, I know you guys have been asked this question a thousand times! But I need to address my excessive inside tire wear before I purchase new tires for my 03 Coupe. First for all I bought this car used with about 24k on it its been lowered with Tien springs and shocks about an 1.5" in the front and about 1" in the rear. I have custom wheels which are Superstars front tires are 245/35/19 S03 Rears are 285/85/19 S03. The problem I having is really bad feathrering on the Front inside tires. The tire noise is almost umbearable at this point. The tires have approx. about 10k on them. I had my Alignment checked and here are my specs below. The rear seems to be wearing just fine. My other question is should I purchase Adj. camber arms for the front to correct my tire wear? I would greatly appreciate any advise!
Front Camber L/F -1.40 R/F -1.20
Front Caster L/F +8.60 R/F +8.40
Toe L/F + 0.00 R/F +0.00
SAI L/F + 5.00 R/F +5.00
Toe Out On Turns R/F +1.70 L/F +1.70
Rear Camber L/R -1.70 R/R -2.00
Toe L/R +0.02 R/R +0.12
Old Mar 20, 2006 | 03:31 AM
haze's Avatar
front camber is fine (right at the edge of spec)
front caster is fine
frone toe is fine of course
SAI (within spec)
rear camber (the right side slightly off OEM range, but should be alright)
rear toe should need some attention
that's just my elementary take on it, someone expert should chip in.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
