Dyno for Stock car
Old Mar 24, 2006 | 03:01 AM
jim5437's Avatar
Dyno for Stock car
has anyone dyno your G35 coupe 05+ when you are 100% stock? If yes, how much rwhp and torque did u have?
thanks
Old Mar 24, 2006 | 03:20 AM
nightrider's Avatar
^^+1
Old Mar 24, 2006 | 10:21 AM
trey.hutcheson's Avatar
Try using the search. There are plenty of stock dynos available for every model year, manual and automatic. But your question leads me to ask: do you really understand dynos in the first place?
Old Mar 24, 2006 | 10:28 AM
vipv35's Avatar
my 6mt 05 g35 out down 242 at the rear wheels.no torque numbers tho
Old Mar 24, 2006 | 10:38 AM
HansMoleman's Avatar
Bone stock with 2500 miles.
Old Mar 24, 2006 | 12:13 PM
FI'ed G's Avatar
^ I assume this is Automatic
Old Mar 24, 2006 | 12:15 PM
mine is a 6 speed.
Old Mar 24, 2006 | 01:10 PM
JC79G35's Avatar
Generally, 6MT models have a 18-20% drivetrain loss (depending on engine). In the case of HansMolen, 298*.8(20%)= 238.4, so thats pretty good.
With the 5AT models (which 03-current are pretty much the same power wise), you're looking at a 23-25% drivetrain loss. I wish I dyno'd mine stock because I only have a theory on where I started: based on the mods I put in, my theory is I started somewhere in the neighborhood of 214 RWHP (I am now up to 238).
Best thing to do is get a dyno run bone stock, much better then wondering where you came from (like me).
Old Mar 24, 2006 | 01:20 PM
FI'ed G's Avatar
You can't really compare every stock base dyno because every Dyno are calibrated differently not to mention Temp/elevation. Dyno base are only good if you're adding Mods and comparing Dyno after the Mod is installed. I see a lot of Base stock dyno for Revup engine in the 250's...
Old Mar 24, 2006 | 05:26 PM
ResIpsa's Avatar
Quick lesson on Horsepower/Torque
Check my thread "Dyno Stock 05 6MT Before/After MREV+"
HansMoleman's G35 is making 238 HP because they only reved it to 6250. Remember, horsepower is only a calculation based on torque and RPM's. So, if we assume the Dyno operator had run the car to 7200 RPM and if the car was making aprox 190 lbs of torque (perfectly reasonable for a 2005 6MT) the same car would make 260 HP.
HP = Torque x RPM/ 5252
I know what you are thinking "where did the 5252 come from?" It has something to do with a horse and a weight. Google it.
That's why 200.5 lbs of torque at 6250 RPM = 238.6 HP
I calculated this by reversing the formula. You can determine torque when you have horsepower and RPM's. or...
Torque = HP x 5252/ RPM
Old Mar 24, 2006 | 05:34 PM
FI'ed G's Avatar
^ That's why i assume (HansMoleman Dyno) was an Auto because it wasn't rev all the way up to 7000.
Old Mar 24, 2006 | 09:03 PM
yep.. they dyno'd a 03 right before me with the 6500 rpm redline.
So they assumed mine was the same.
Old Mar 24, 2006 | 09:25 PM
Mr_pharmD's Avatar
Mustang dyno always reads less therefore his numbers seem low but when compared to the dynojet its ~250s.
Old Mar 25, 2006 | 12:23 AM
ResIpsa's Avatar
Your falling into the "dyno myth" that infests this forum. HansMoleman's G made less horsepower because it was only run to 6250 RPM!!!!
I AM NOT BLOWING SMOKE HERE, THIS IS THE TRUTH.
If his G had been run to 7200 RPM it would have made +/- 260 horsepower.
Old Mar 25, 2006 | 02:06 AM
Mr_pharmD's Avatar
260hp on a mustang dyno?? I doubt it
