Shifting points for straight line speed
Old Apr 2, 2006 | 06:08 AM
haze's Avatar
Conditions:
For 5AT, 280HP VQ35DE engines.
No mods.
VDC off
Dry
As brought up in another thread, I was wondering what is the best shifting points through each gear for the best straight line speed. I used to this "kissing" the redline is the best method for our G, but that thread had made me think other wise.
Speed gurus please chime in, thanks for all!
Old Apr 2, 2006 | 06:11 AM
ZLUJ's Avatar
Mmhm...
automatic mode? Theres not much more you can do with the manumatic mode, than just taking it a little further..
Old Apr 2, 2006 | 10:39 AM
ChicagoX's Avatar
Don't drink and Mag Race
In my experience, shifting in MM mode is worth about one tenth, or about one car length in the quarter. Possibly two, if you are requiring a shift into fourth in auto mode.
Old Apr 2, 2006 | 02:21 PM
haze's Avatar
GEE PASTA, i hope you don't mind if I quote you.
Originally Posted by GEE PASTA
The sweet spot is much lower than you think, You may need to work on your driving style. Over driving your engine is wasted motion.
Old Apr 2, 2006 | 03:26 PM
Funner567's Avatar
dont use manumatic mode in a race. leave it in "D" as it will shift at the correct times better, but if your racing from a rolling start drop it into 2nd or 3rd depending on your speed and work it from there when hitting just a line over redline. dont forget we have lag on our upshifts so hit the shifter a little earlier.
Old Apr 2, 2006 | 03:48 PM
savefatkids's Avatar
leaving it a D will slow u down. ive tried it and in MM mode the car feels faster and u can also shift at 7 instead of 6800 thats what i do.
Old Apr 2, 2006 | 05:20 PM
haze's Avatar
leaving it in D definitely slows one down, because it takes more time for the tranny to respond to the gas pedal and downshift accordingly.
Old Apr 2, 2006 | 05:49 PM
BracketRacerSteve's Avatar
I was just at the track yesterday soooo..........
Left in auto mode I ran a 14.559@96.77, the car did shift to 4th before I hit the traps.
Manumatic shifting next run I got 14.503@97.61, I shifted about 200-300 rpm higher than auto mode does, and went thru the traps in 3rd gear at about 6400 rpm.
When I turn on the juice I leave it in auto mode, best run with 100 shot was 13.409@107.18
Old Apr 2, 2006 | 09:08 PM
haze's Avatar
so patton, from your experience, you're implying that there is negligiable difference in straight lines using auto and manumatic mode?
Old Apr 2, 2006 | 09:42 PM
I didn't imply anything
I just listed my results and how I achieved them
There may be a larger difference between Auto and Manumatic for someone who doesn't have a Groundinggear kit. I also expect to pick up a couple of tenths once I get the valve-body upgrade done. The tranny struggles a bit with the 100-shot of nitrous.
Old Apr 3, 2006 | 12:15 AM
Funner567's Avatar
i dont like to redline so we are a bit different. and from a dead stop i brake torque to about 2500 so i dont really lag.
Old Apr 3, 2006 | 03:19 AM
haze's Avatar
sry patton, i don't actually mean that you've implied what i said. i should have made it clearer, it was just my inferences.
Old Apr 3, 2006 | 03:32 AM
MikeyMike's Avatar
Rollin On Dubz
In my experience
The car shifts a lot more aggressive in MM, even if I just leave it in 4th gear on MM and I'm not necessarily doing the shifting myself from 1-5.
Old Apr 17, 2006 | 04:52 AM
haze's Avatar
so in the end, can someone give some more specific suggestions as to where are the ideal shift points?
Old Apr 17, 2006 | 10:25 AM
lightforce18's Avatar
So MM mode is slightly faster in the 1/4?
